MF240 hydraulics
Kalle
10-13-2003 08:55:04
Hi there gentlemen
A friend of mine has a MF240-2 year -80. He has problem with the hydraulics. He bought it three years ago and so far he only used it hauling a trailer. So he has not been in need for any lifting. Is there a switch valve for 3p-lift/ext hydraulics (it is equipped with "lots of hyd. hoozes" for external use. He seems also having trouble making the PTO run. Any hints?
W B R
Kalle
Rlach
10-13-2003 09:13:21
 Re: MF240 hydraulics in reply to Kalle, 10-13-2003 08:55:04
it is equipped with "lots of hyd. hoozes for external use" could implies a lot of troubles, air pockets, ...; I had a similar trouble on a 275 and I moved (back and forth and many times), the flow adjustment lever (RH cover)and the hydraulics came back. Hope it helps.
Rlach
Kalle
10-13-2003 23:49:03
 Re: Re: MF240 hydraulics in reply to Rlach, 10-13-2003 09:13:21
I think i suggest him to take away some of the ext.hydraulics. Don�t think he need them at the moment.
By the way, where is the pump located - in the gearbox or at the engine or ? Neither myself or my friend has experience of MF.
W B R
Kalle
