Massey Ferguson 2135
Dale13
10-13-2003 07:54:35
Can anyone tell me anything about a 2135 turf special,year,size motor,horse power etc. Will be used on a 7 foot bush hog,if it has enough power.
Kenrat
10-13-2003 20:37:46
 Re: Massey Ferguson 2135 in reply to Dale13, 10-13-2003 07:54:35
I have a spec sheet on the 2135 to send you but your email is blocked. Kenrat
Dale13
10-14-2003 17:32:33
 Re: Re: Massey Ferguson 2135 in reply to Kenrat, 10-13-2003 20:37:46
My e-mail should show now..
kenrat
10-14-2003 18:07:23
 Re: Re: Re: Massey Ferguson 2135 in reply to Dale13, 10-14-2003 17:32:33
Dale, I can't find it. Did you also check NO beside hide. I can't seem to get the spec page to paste to the forum. Email me direct at [email protected] What year is your 2135. I am guessing mine is a 1966. SN 648000421 but I can't find it listed anywhere. Ken
Charlie
10-13-2003 08:14:01
Dale13
A MF 2135 is approx the same size as a MF 135, 38-40 hp. Basically the Turf Special is a Lower Center of Gravety (LCG)tractor smaller rims and wider tires and a wider stance better for stability. These tractors came with dsl and gas motors. I do not think that you will be able to carry a 7' foot bush hog with your tractor. I believe that the weight will lift your front end off the ground, also a 7' will most likely bogg your tractor down in heavy grass or brush. (that will all depend on what you are cutting) The main issue is the weight of the 7' bush hog. hope this helps
