Pony hits on 3 when cold
Dave_Id
10-12-2003 14:14:38
I first thought it to be a stuck valve,(it still might be) because it was sitting for a long time. When I finally fired it up, it was only hitting on 3 cylinders. But when it warmed up it hit on all 4 and ran beautiful.. no smoke. I thought it was cured, but this weekend when I fired it up, the same thing happened. The compression reads 85,85,65,85. Plugs look good. Any ideas? , or do you folks think a sticky valve is the culprit?
Allan C
10-12-2003 16:15:13
 Re: Pony hits on 3 when cold in reply to Dave_Id, 10-12-2003 14:14:38
Could be a sticky valve, could be a cracked head/leaky gasket that is allowing moisture into the cylinder, or could be a spark plug with a cracked electrode. They will miss when cold. Start with the sparkplug. If it proves o.k. add a little ATF to the gas and run it for a while,(like a pint to a tankful) this should help the sticky valve business.
loretta richter
06-20-2007 17:21:01
 Re: Re: Pony hits on 3 when cold in reply to Allan C, 10-12-2003 16:15:13
can you show or tell me the firing order of a massey pony tractor. my father-in-law can't figure it out.
loretta
Dave_Id
10-12-2003 16:46:35
Thanx Allen, I'll slap in four new plugs first. I had 6 stuck valves when I first started on my 101 Senior, but as soon as they were freed up, they were free for good. I'll also try the ATV...
