165 multi power
G Cole
10-12-2003 10:04:49
My multi power used to work fine. It started to hesitate like the clutch was pushed in a little then it would do ok. I had engine braking. Now the slipping has gotten worse and I have no engine braking. Is it the clutch or multi power. How hard is it to fix the multi power
Lee in MI
10-13-2003 17:36:40
 Re: 165 multi power in reply to G Cole, 10-12-2003 10:04:49
Did mine last year. You have to remove the trans completely, which means you split the tractor twice, once at the bell house and once behind the trans. If you want I can email you some pics of trans and the parts that when bad on mine. Good luck with yours.
JEM
10-16-2003 12:20:01
 Re: Re: 165 multi power in reply to Lee in MI, 10-13-2003 17:36:40
Heres somethings to check before you tear down.First is the hydraulic oil level,condition and filter screen.Then check the Multi Power shift linkage.The switch control valve is located on top of the clutch housing,ahead of the battery,underneatth the steering box.Sometimes the arm which clamps to the switch valve stem works loose,slips and doesn`t push the valve all the way down "into high".Remove battery and panels;adjust arm to the end of the stem and retighten.The dash lever may require adjustment which is done on the rod on the left side.A bit tricky;I set mine every year when it acts up and it works.Good luck.
