102 Junior
Harold
10-09-2003 19:10:01
Hi; Does anyone know where to look for the serial number is on a 102 Junior and are they a much sought after tractor. Thanks----Harold
Alberta Mike
10-10-2003 12:05:16
 Re: 102 Junior in reply to Harold, 10-09-2003 19:10:01
Obviously, the tin oval plate on the tractors left side is missing. The serial number is also stamped into the upper machined surface of the transmission/differential case between the shift lever platform (with the 1,2,3 etc. numbers on it) and the steel cover plate which bolts down over the rear end gears. It is between these two covers on the left side near the clutch pedal. You'll have to scrape and wire-brush, they are hand-stamped and sometimes not too deep. Post it here and someone will ID the year for you. They are a nice little tractor, easy to work on etc. but certainly not rare by any means. Originally the 10 Juniors were the low-grade fuel models. The original 101 Juniors were the gas ones. Up here in Canada after about '43 or so, all Juniors were designated as 102's.
Harold
10-10-2003 18:53:18
 Re: Re: 102 Junior in reply to Alberta Mike, 10-10-2003 12:05:16
THANKS for the info Mike, Now the guy cant make up his mind whether he wants to sell it or not. A few days ago it was just scrap but when he heard I want to restore it, it is becoming more valuable.Its not to often two Canadians chat on here, I am in Sask.-----Harold
Dave_Id
10-11-2003 18:28:55
 Re: Re: Re: 102 Junior in reply to Harold, 10-10-2003 18:53:18
As Mike mentioned, they are not all that rare, even lots of them down here in Idaho.. keep looking if he gives you anymore crap, or make an offer, wait a week, then go looking.
