165 CLUTCH???
jamie
10-08-2003 18:37:50
MY PTO WILL NOT GO INTO GEAR,IT JUST GRINDS. MY MAIN DRIVE CLUTCH WORKS FINE. IS IT POSIBLE TO WEAR OUT THE PTO CLUTCH BEFORE THE MAIN ONE OR DO I HAVE TO ADJUST SOMETHING ELSE THROUGH THE INSPECTION PLATE? IT GOT USED ALOT THIS YEAR WITH THE NH 847 BALER AND A 10 FT HOG.
THANKS FOR ANY HELP YOU CAN GIVE! JAMIE
Turn off Your All Caps Ke
10-10-2003 05:23:27
 Re: 165 CLUTCH??? in reply to jamie, 10-08-2003 18:37:50
Quit shouting at us, if you want help.
fergi
10-09-2003 17:00:26
My 165 started doing the same thing, I didn't even have to go in through the inspection cover. Did it all with the pedal linkage. I had to really tighten down on the locking bolt to keep it from moving after I got it adjusted right.
jamie
10-09-2003 18:50:09
 Re: Re: 165 CLUTCH??? in reply to fergi, 10-09-2003 17:00:26
IF YOUR TALKING ABOUT THE SHAFT THAT COMES OUT OF THE TRANS CASE THAT ONE IS ADJUSTED AS FAR AS IT GOES
fergi
10-14-2003 18:42:13
 Re: Re: Re: 165 CLUTCH??? in reply to jamie, 10-09-2003 18:50:09
Mine was a 2 stage clutch, it was kind of tricky for me to get it right, couldn't feel the free play like I thought I would. I used a welding rod to measure the 1/8 inch of free play.
