Will not start! Massey Harris #22
PGNS
10-06-2003 08:46:39
I just bought a #22. The battery was dead and The carb was dirty. I bought a new battery and cleaned the carb and tried to start her. It would turn over easy enough but not catch. It is getting gas because I pulled the plugs and they were wet with fuel. The wires need changing and the distributer cap has some corrosion inside the terminals. If I replace the wires and cap will this solve my problem? What else should I look for? Thanks
Alberta Mike
10-06-2003 09:30:39
 Re: Will not start! Massey Harris #22 in reply to PGNS, 10-06-2003 08:46:39
You didn't mention if you had checked whether or not you were getting spark at the plugs. That would be an obvious check to do and then you could progress from there.
off the land
10-06-2003 10:09:13
 Re: Re: Will not start! Massey Harris #22 in reply to Alberta Mike, 10-06-2003 09:30:39
Mike, I really don't want to see the inside of that Dist. Cap. Why don't you take the flying "s"
on a service call? Since you probably have a match
140 in your V, better grab the rotor & condensor,
they must look ugly. Glad you are on this one.
Good luck.
