Miss or dead spot about 1300 RPM
snowey
10-05-2003 21:00:53
My MF 230 about 1978 with miss or dead spot about 1200 rpm . If going down light grade in high gear will pass 1500 rpm and run great , if tractor stopped and motor speeded up will go to 1400RPM gage swing back to 1200 RPM then go to hi goverer RPM . Have a 5 ft. brush hog and finsh mower with loader , love tractor not the miss . (Perkins Diesel motor)
snowey
10-08-2003 20:34:32
 Re: Miss or dead spot about 1300 RPM in reply to snowey, 10-05-2003 21:00:53
Note , not gas motor !!!!! (Perkins Diesel Motor) snowey
STEVEN H
10-08-2003 07:54:09
i would say that either the carb has a bit of dirt that is built up on the needles or the govornor might have a spot where it catches for a moment. i would try runing some carb cleaner in the carb and see if that dont take you miss right out. i suggest sea foam my self as i have use that for many applications with the fuel system and have not been unhappy with it at all. i lean more tward the carb than a sticky gov, but i have not seen what the gov looks like on that tractor
