Massey 180
Ken Craig
10-02-2003 12:41:09
I just moved to a 160 acre place with a mile long driveway and have a 180 Diesel to do the snow plowing thing. The tractor has no gear shift pattern diagram. Is there someplace I can get a shift pattern and some advise how to run the tractor for plowing.
Josh
10-03-2003 08:24:17
 Re: Massey 180 in reply to Ken Craig, 10-02-2003 12:41:09
The small lever to the left of the steering wheel is the multi-power, push it up for high, pull back for low. There are two levers to the right of the steering wheel. The one closest to the wheel is the high-low range shifter. Forward is low, the middle is neutral (tractor must be started with this lever in neutral), and the next lever is the main shirt lever. The the left and up is reverse, down is 1st, to the right and up is 2nd, down is 3rd.
