MF 65 Brakes
Jim in Oregon
10-02-2003 08:50:33
I am trying to install new brakes on my MF 65. I have a manual from MF, however it is unclear how much I have to tear apart to get to the brakes. I have the rear tires off and the axel ready to remove, but I'm not sure how to proceed from here. Help!!
Thanks,
Jim
David B
10-03-2003 18:03:50
 Re: MF 65 Brakes in reply to Jim in Oregon, 10-02-2003 08:50:33
You don't have to take the short axles and the planetary drive apart but need to remove the complete assemply at the differential case. Remove the lift arms or at least the lifting part from the lower arms and get a cherry picker to hold the axles while you unbolt from the differential. Also must disconnect brake linkage from pedals. A little envolved but no big problems. I wouls do them one side at a time.
bob
10-02-2003 19:37:00
you dont have to pull axles, just remove hub & there they are. Loosen the gigantic screw that holds hub on, then pound hub between lug nuts til vibration lossens hub. Tap outside back rim of hub & pull it off w/your hands.
Jim in Oregon
10-03-2003 08:29:59
 Re: Re: MF 65 Brakes in reply to bob, 10-02-2003 19:37:00
Thanks for the info bob. I have removed wheels and hub that has splines that holds wheel on, where is the hub you are talking about? I have also taken the wheel axel assembly off, do I have to go even deeper to get to the brakes?
Thanks,
Jim
Bob
10-04-2003 18:59:27
 Re: Re: Re: MF 65 Brakes in reply to Jim in Oregon, 10-03-2003 08:29:59
I believe the previous post from bob applies to smaller models like the 35 and 50 which have automotive type drum brakes. The 65 is different. It has inboard disc brakes. If you have already removed the axle housing from the differential, you will notice a large round plate attached to the axle housing with two Allen head bolts. Remove these bolts and the plate and you will see the brake discs.
Jim in Oregon
10-07-2003 10:52:19
 Re: Re: Re: Re: MF 65 Brakes in reply to Bob, 10-04-2003 18:59:27
OOPs!! Thank you, Bob. I think I've already gone too far. I will back up and check out the axle housings.
Thanks again.
Jim in Oregon
