MF 55 3 bottom rollover plow
Jeff from Worla
09-30-2003 20:29:57
I have a spring loaded mf 55 3 bottom rollover plow which lays on its side when I lower it into the ground. It appears that the 'back' end of the plow is pulling away just enough to release the latching mechanism. Try as I might I was not able to find a shear pin or adjusting bolt. It seems that this is a safety which dis-engages the plow to avoid bending or breaking it, but I am not sure. Does anybody out there have any ideas, or suggestions??
Thanks for your help
Jeff
CH
10-03-2003 03:50:00
 Re: MF 55 3 bottom rollover plow in reply to Jeff from Worland, 09-30-2003 20:29:57
Actually, I believe it's a safty to keep from flipping the tractor if you snag the plow. Other than that, I can't help you.
