Massey harris flathead engine
Mike(MN)
09-30-2003 15:50:41
Got a flathead engine that is a Massey Harris four cylinder
What did it come out of?
It's on a home made wood splitter now.
Thanks in advance
Jerry ,L.I. ,N.Y.
10-01-2003 11:07:20
 Re: Massey harris flathead engine in reply to Mike(MN), 09-30-2003 15:50:41
M-H Link-- m-h.cs.uoguelph.ca/pony-- Flat head pony 4cyl. Model # 62 = 62 cu.in. Their is a gent on this link, Big Dean retired M-H tech. Hope this helps.
Jerry
Dave_Id
09-30-2003 17:49:16
Without an engine tag, it's pretty tough to tell. The 101 Jr's had flat head 4cyl as did the Pony If it has a tag, it may tell you what cubic inch engine you have
Garry
10-01-2003 09:02:28
 Re: Re: Massey harris flathead engine in reply to Dave_Id, 09-30-2003 17:49:16
I have a MH 30 with a flathead 4 cylnder
off the land
10-01-2003 09:29:50
 Re: Re: Re: Massey harris flathead engine in reply to Garry, 10-01-2003 09:02:28
Since you refer to it being out of a Massey-Harris,does it have that name cast into the exhaust manifold? If correct, probably a 162 out of a '50, or newer model 30. The block appears identical on a 140, from a 22, but smaller bore.
