MF 50 Front End Loader
Robert Blackbur
09-30-2003 04:20:12
Looking for a front end loader for a MF50....
Can I get a new one and what price I'm I looking at?
Names of companys I can call
Thanks for your help
Charlie
09-30-2003 09:09:18
 Re: MF 50 Front End Loader in reply to Robert Blackburn, 09-30-2003 04:20:12
Robert
If you look in the photo ads (ad no 47411) there is a Davis loader off of a MF 135 that may fit yor MF 50. It is located in KS, not sure where you are located, something to look and at.
Charlie
09-30-2003 08:19:38
Robert
If you call around to your local tractor dealers, they usually sell loaders. The price will all depend on what you want, where you are located and which brand you choose. (approx $3500 to $4200) You can look on the web search engines and find all the information you will need. (price, location, options etc) Bush Hog, Great Bend, Woods and Allied are very good loaders. I would RECOMMEND that you add a front mounted hydraulic pump to run the loader, instead of tapping into your existing hydraulic system. (the pump and hardware can be $700 to $1000 installed) The pump has a greater gallon per minute rating than your tractor has. You may want to call your local used tractor dealer and see if they have a used one on site that can be altered to fit your tractor. Example MF 50 is close in size & shape to a 3000 Ford and a loader from a Ford may work with some slite alternations. Hope this helps
bob
09-30-2003 21:29:16
 Re: Re: MF 50 Front End Loader in reply to Charlie, 09-30-2003 08:19:38
robert- I have a front-mounted pump for sale off a Ford 3600. It powered a Ford 776b loader. I dont need it because my tractor is the newer type & I am better off hooking into the transmission of my Ford 3910. I am in west virginia.
Robert for Bob
10-01-2003 10:11:33
 Re: Re: Re: MF 50 Front End Loader in reply to bob, 09-30-2003 21:29:16
How much do you want for the front-mounted pump?
