1000. for my 50 good deal
jeff in santa r
09-29-2003 18:43:20
I paid a grand for my mhf50. got it home and with a feww hours work got it started. runs good! the guy said it had water getting into oil. I have'nt seen it yet. will somebody respond? every time i post, nobody answers back!
Charlie
09-30-2003 08:28:19
 Re: 1000. for my 50 good deal in reply to jeff in santa rosa, 09-29-2003 18:43:20
Jeff
Hello, Sound like you got a good deal on that tractor. Is it gas or dsl??? What other options does it have? What are you going to use it for?? Or is it just a big toy??
jeff in santa rosa
10-09-2003 00:58:23
 Re: Re: 1000. for my 50 good deal in reply to Charlie, 09-30-2003 08:28:19
thanks for the response, charlie. i'm going to use it for hay cutting, raking, pull the baler and such. maybe pull the disc. It is a big improvement over my 8n. it has 2 stage clutch, hi low range, live pto(i thought the guy said 2 speed pto, but i only get 1. i need to check the block at some point, the guy said it had a crack betwwen one of the sleeves, letting water into oil, but so far, all is well.
off the land
10-10-2003 09:53:04
 Re: Re: Re: 1000. for my 50 good deal in reply to jeff in santa rosa, 10-09-2003 00:58:23
If the seller stated it was cracked, be prepared.
This was a common fault with the 50, some are able
to be fixed, others need a replacement block. You
would be wise to attempt fixing it now, before the
repair cost more than the tractor. Your bargain may end up as a barkyard ornament. Check the
archives here, for MHF 50. There are places that were able to repair 'some' of these blocks. Good
luck.
