massey harris picker engine
troth
09-26-2003 20:59:25
Can anyone tell me which Continental engines were used in Massey Harris self propelled corn pickers? I have the opportunity to purchase two pickers one with the four cyl and the other with the six cyl. I want to locate the rebuild kits before I make my decision.
David B
09-27-2003 18:49:31
 Re: massey harris picker engine in reply to troth, 09-26-2003 20:59:25
I know of a self propelled M-H picker setting and rusting down in a stage way to late to save that has the 4 cyl flat cont engine I think is 162 cube the same as my 101 Jr. Checked it out when looking for a 44-6 manifold. I don't know if this is an early model, there were options on engines or why the 4 cylinder but thats what it had. Most advertisments I have read always called for the 226 cube 6 cyl.
Jim
09-27-2003 15:16:49
off the land
09-27-2003 13:47:43
The F226 was used, a flathead six, same as the 44-6 engine. A four cylinder? Don't recall that one.
Perhaps a model change? Repower? Is it a OHV or
flathead? Any numbers under the manifold, or on tag, by the oil check stick? Mysteries. Good luck.
troth
09-27-2003 19:33:32
 Re: Re: massey harris picker engine in reply to off the land, 09-27-2003 13:47:43
Thank you for the tip on the F226, neither engine has an ID tag on it. By the way, the four cyl, a continental flathead, was used in the first series with serial #'s 8101 and up. They are recognized by a rounded top on the tall air cleaner stack. The six cyl was in the second series serial #'s 12001 and up which had a triangle air cleaner stack.
To bad Alberta Mike spends so much time around area 51 dream land instead of learning something isn't it :~)
Alberta Mike
09-28-2003 06:28:10
 Re: Re: Re: massey harris picker engine in reply to troth, 09-27-2003 19:33:32
Well actually, the reference to flying saucers is a little private joke between o-t-l and myself and was really directed at him, not the original post. Sorry if anyone misunderstood that ... actually I've learned a thing or two myself here on the MH forum.
Alberta Mike
09-27-2003 14:12:17
Well M.Y..... maybe another one of those flying saucers that have been appearing in the MH skies lately. Hope those arenn't in the vicinity of area 51.
