MH30 Motor upgrade
Paul
09-26-2003 08:59:36
I was wonderiing what motor size I can go to in this tractor and will it still look stock. I was thinking a motor from either a 33 or a 44 might work but am not sure. Any help would be appreciated.
steve malecha
09-26-2003 17:07:48
 Re: MH30 Motor upgrade in reply to Paul, 09-26-2003 08:59:36
Both the 44 and 33 engines look different
Don
09-27-2003 04:39:45
 Re: Re: MH30 Motor upgrade in reply to steve malecha, 09-26-2003 17:07:48
a 33 or 44 will bolt right in. a motor out of a standard might have the right length prop shaft. Overhead valves are a good thing. Don
off the land
09-27-2003 13:22:16
 Re: Re: Re: MH30 Motor upgrade in reply to Don, 09-27-2003 04:39:45
The engine may be a drop in, with the bell housing
but the components will bring conflict. If you have hydraulics, it's a reverse. Going with a 44
Standard engine,will mean adding that radiator. Your sheet metal is too low, you need a 7 rib grill, to replace your 6 rib grill. Fuel tank supports need the swap, also. Front wheels on
44's were 6.00x16, 30's about 5.00x15. With so much change, why not just buy a 44? If intact,it's
all there, correct rear wheels,etc. Good luck.
