MF TE20
ian
09-25-2003 04:42:32
Am about to purchase MFTE20 for light paddock duties. I know nothing about them other than it's a 4 cyl petrol engine, probably standard vanguard, any words of wisdom? What should I be looking fo, how much should I spend?
Thanks in advance
Ian
Rick
09-27-2003 06:11:59
 Re: MF TE20 in reply to ian, 09-25-2003 04:42:32
Firstly you need to know if its a standard motors ( a TEA) or continental engine (TE) ( the latter are pretty rare) Then check the serial number on the plate under the steering wheel. Look for tractors with serial numbers above about 250,000 They will be 12v and have other improvements such as stronger rear axles.Tractors below about 176,000 are 6v and 80mm bore and have 23.9 hp compared to the later versions with 85mm bore and 28 hp. The difference is worth having. The last of them ( serial numbers avove 487000 odd) have the Zenith 28z instead of the zenith 24 t2 carb, better rear axle seals and hydraulic pump improvements . The hydraulics are not live so if want something to use on a PTO a lot forget it but then again if want something for linkage work with small implements in confined spaces they cannot be beaten . I drove one when I was 5 years old and its still fun at 52!
