SHANNON
09-26-2003 13:21:12
Re: Re: Re: Re: CAN HYDRAULIC PUMP OFF MH 44 FIT O in reply to STEVEN H, 09-26-2003 07:01:58
thanks..just wanted to know what it can fit and cant fit...yes i know the parts are real hard to find for mh 55..the one im looking at is in real good shape, probably dont have to worry about rebuilding for long time.. the frist mh 44 with widefront im all finished up painted and all that works. in my house garage! i cant do that anymore, because of that paint and not much room, also i have a big barn but its not wise to paint or eles in that barn, no concrete or electric so im going to build me a shed sometime and guess what, im getting married next month so thats the reason im so busy. anyways all 3 of them are just sitting in the barn all cozy up together..the 2nd mh 44 with missing firing, i did everything i could think of, new plug wires, spark plugs and ingition, points, caps.. it didnt solve the problem. it has really good compression, i think it needs to be adjusted on valves or it could be a weak spring valve that let it open when piston was going down? otherwise it runs real good..but still has no fire in number 3 piston..i think the head needs to be working on.. so thats a big job im saving when im not busy.. other mh 44 just needs valve guide seals.. thats all then paint them up and put new tires..still i want to have mh 55, they are huge..yes i know they are real hard to find parts.. money is no problem for me..which i doubt that mh 55 will give me any trouble for long time..just paint it up and change all fluids, keep in top shape that thing will last u a long time, which i plan not to use all times just drive it around and pull something thats all, it sounds a easy job for mh 55 to do it..i want to know some more about mh 55 what parts can fit and what cant.. its something that you dont see mh 55 all times everywhere you go to the festivals.. still i have not seen mh 55 around here! so that would be cool to have one while others dont ha...someday i might have a competely set of massies.. 55, 44, 33, 101jr, 22, colt, mustang, and of course a pony! who knows! greatly appricate your thoughts and feedbacks.. i wouldnt mind to have mh 55 if it runs or not, just love to have it sitting in my yard and look at it! thanks everyone shannon bone
