TO-35 Engine Block
Joe H.
09-23-2003 20:28:25
Can an engine block which is cracked between cylinders be repaired? Or is it just good for a door stop? If it can be repaired what is the best way to do that?
Randy
10-02-2003 22:05:37
 Re: TO-35 Engine Block in reply to Joe H., 09-23-2003 20:28:25
I've heard of some being drilled through the block and a threaded rod put through and nuts put on the rod and then tightened to close up the crack. Some can be welded up too.
