LARGE PIN UNDEREATH THAT HOLDS DRAWBAR ON MH 44
SHANNON
09-22-2003 23:46:46
i was taking the drawbar off to have it sandblasted and repainting.. i noticed the large pin under the transmission housing and bracket that goes across to hold drawbar in place. the pin is like half worn out! any idea how to take it out and where can i get a new pin? if i try to pull anything real heavy, it looks like it could snap in half and who knows how much damage it can cause.. any advices how to take the pin out?
thanks again shannon
Alberta Mike
09-23-2003 07:40:43
 Re: LARGE PIN UNDEREATH THAT HOLDS DRAWBAR ON MH 4 in reply to SHANNON , 09-22-2003 23:46:46
I'm not too familiar with the 44 setup you have but on 101's, you have to remove (or at least drop the end of) the drawbar frame assembly to get that off. I would think a good steel bolt (cut to the proper length) would do the job as a replacement.
