Pony axle seal help
Kelvin
09-15-2003 18:11:02
Anybody know a part number I can cross reference?
Also, are there any things to be aware of before I try to replace the seal, like tricks to getting the axle out?
thanks!
Kelvin
Ken in Iowa
09-15-2003 20:21:32
 Re: Pony axle seal help in reply to Kelvin, 09-15-2003 18:11:02
Kelvin: I changed mine a couple years ago and found that the axles and brakes can remain in the axle housing. Securely block the tractor up and it's best to get a helper to slide the assemblies off.They are heavy! I couldn't find the wide seals in my area so I installed 2 narrow seals in each side with a little grease between them. Try a NAPA store or maybe you can cross reference.
Seals for diff/axles 2 on each side, NAPA #11223, 1 1/8 ID & 1 7/8OD X � thick. Good luck, Ken
Kelvin
09-17-2003 18:38:39
 Re: Re: Pony axle seal help in reply to Ken in Iowa, 09-15-2003 20:21:32
Thanks for a reply. I just put in a differential seal, but its leaking almost as bad behind the hub where the wheel bolts on. That's what I meant by axle seal.
Thanks!
Kelvin
