No 12 baler roller chain
Tom Smith
09-15-2003 17:32:29
Does any one know the number of links in the #80 roller chain that drives the pickup and knotters?
this is the chain on the end of the plunger crank between the case and pickup. thanks Tom
STEVEN H
09-15-2003 20:57:57
 Re: No 12 baler roller chain in reply to Tom Smith, 09-15-2003 17:32:29
i dont know the #, but i have the baler out on the lawn so i could count it for you. must have had a chain brake huh
Tom Smith
09-21-2003 17:29:25
 Re: Re: No 12 baler roller chain in reply to STEVEN H, 09-15-2003 20:57:57
Steve, I don't have a parts book and the man took it home after I got it adjusted. the chains are all stretched alot but he wanted to use it anyway. This is the first baler I've seen where the plunger is so tight you can't turn it with the flywheel after loosening all the guide bolts you couldn't hold your hand on the bale chamber it was that hot. anyway he was warned it needed more work. don't count the links if I get it back I'll do it then. thanks Tom N.E. Ga.
