Carb. trouble I think.
lp
02-25-2000 20:16:34
What's wrong with my TO 35 gas tractor? It is burning too much gas and it has black smoke at the exhaust pipe when you open it wide open and when you decelerate. Please tell me what to do I have changed the points, plugs, condenser and wires. Please give me some instructions on how to adjust the carb. or what else to look for.
Gerald J.
02-26-2000 11:01:30
 Re: Carb. trouble I think. in reply to lp, 02-25-2000 20:16:34
There's adjustment screws for mixture, probably on one on top the carburetor for high speed. turn it in to lean the mixture. But first replace the float needle and seat. Its probably not sealing and so over fills the bowl and that makes the mixture rich and variable.
I've found my MF-135 gets a little more pull on the plow when running a tad rich.
Gerald J.
