44 pull results
jerry
09-14-2003 21:31:56
just returned from the first pull with 44 with tricyle front end,it weighed in at 4990 with no weight added,i got third out of seven but had to stop becouse of frontend came of the ground too high.still had power to go futhur.what is better for pulling distance calicium or none in tires,or weight in the front of tractor
Don
09-20-2003 06:02:09
 Re: 44 pull results in reply to jerry, 09-14-2003 21:31:56
Jerry; run your tires dry, then put the weight where you need it. A44 will weigh under 4500 with stamped steel rims. when you build you weight brackets, build your wheelie bars. afterall, it's your but the tractor will try to flip over on.
