MF-65, Problem Starter..
Mat
09-13-2003 09:42:52
On a number of occasions when attempting to start my MF-65 the starter motor simply whirrs..and at other times can start with no problems. i have tried giving it a shake incase the starter and engine are not engaged. Any ideas would help greatly.
Peter
09-14-2003 11:26:14
 Re: MF-65, Problem Starter.. in reply to Mat, 09-13-2003 09:42:52
To 99% it is bendix problem.
Allan C
09-13-2003 19:29:03
Most likely it's the one way clutch in the drive. You'll have to replace the drive. Which you can do yourself if you're at all mechanical.
Tom
09-13-2003 13:33:56
Mat,
Take off your starter and solenoid. Take both to a local starter rebuilding place. Explain the problem to them. They can fix you right up.
Roy in UK
09-13-2003 11:50:30
Had a 165 do that, after a lot of tinkering I ended up replacing the solenoid which solved it.
