44 tractor pull
jerry
09-11-2003 21:07:39
first year pulling with 44,what our some ideas for better pulling? its a row crop, gas 4 cyl.it weighed in at 5000lbs.thanks for reponse
buck snort
09-16-2003 09:39:53
 Re: 44 tractor pull in reply to jerry, 09-11-2003 21:07:39
16.9 radial tires
advance timing
turn up fuel
wire governor
cut cam for lug not rpm's
electronic ignition
I pull a 44 myself and do very well, place every time. Nothing is better than a sassey massey.
Les
09-12-2003 14:17:18
If you are pulling pretty much farm stock with un-cut tires etc. I would say raising the compression is your best bet. We have a 44 with 4 1/8 M&W's and this pretty much gives us the power we need to be competitive. Tires that have been wore down and roaded seem to work the best.
Some guys clean the heads and manifolds up to increase flow.
jerry
09-13-2003 13:48:23
 Re: Re: 44 tractor pull in reply to Les, 09-12-2003 14:17:18
thanks for your reply les.yes the tires our wore down so i got that covered.i thought that m w pistons went out fo business.what about propane pistons?what about cost of high compressions pistons?where do find them?jerry
Les
09-14-2003 16:00:20
 Re: Re: Re: 44 tractor pull in reply to jerry, 09-13-2003 13:48:23
I'll check to see where my father located the M&W's and get back with you. I'm not sure about the LP or other types. I know the M&W's sure make a difference from a stock 44 or 444.
LArry
09-12-2003 10:28:24
I used to successfully pull a 44 massey in 5000. The thing is, we were not allowed to use cut tires. We also had to run factory RPM's. How much horse power does it have? We also had to pull in 1st gear. Remove your hydraulic pump for mor power.
