Dumb rad fan question
CityBoy
09-10-2003 19:04:54
Don't laugh folks. Just an ignorant CityBoy here, new to tractors, trying to do the right thing.
I have a four bladed fan blade on my recently acquired MF35 gas. The cupped side of the blade faces the radiator. This seems backwards to me. I asked the previous owner about this because I know he did some engine work on it a few years back and had the engine partially disassembled. He said he didn't remember which way the blades should face, and added that his son helped put things back together.
So does the cupped side face the radiator or the engine?
C. T. in Oklahoma
09-12-2003 16:07:42
 Re: Dumb rad fan question in reply to CityBoy, 09-10-2003 19:04:54
My MF/FE 35 Perkins diesel has the cupped side towards the engine. C. T.
CityBoy - Thanks
09-14-2003 12:39:46
 Re: Re: Dumb rad fan question in reply to C. T. in Oklahoma, 09-12-2003 16:07:42
I flipped the cupped side toward engine yesterday. The difference is air volume was quite astounding.
dodgeboy
09-11-2003 18:12:57
Cityboy Marlow is right. Reversing the fan doesn't change the airflow direction. When reversed, the poorly shaped backside is now pulling, and as you have found, very ineficient. It sounds like you just need to reverse the fan. Ray
Wrong Way
09-10-2003 19:58:18
Typically the cupped side should face the engine. You want to pull the air through the radiator, not push it.
marlowe
09-11-2003 11:53:04
 Re: Re: Dumb rad fan question in reply to Wrong Way, 09-10-2003 19:58:18
it all depends if you want a pusher or puller most ind.eq.has pusher fans to blow dirt forward and away also cooler for driver some have fans you can turn. what way dose your fan blow pull or push? some of the last IHC. tractors had a pusher fan . turning the fan will not change air flow . but as the other post said cup to engine side most of the time but not all
CityBoy
09-11-2003 17:44:09
 Re: Re: Re: Dumb rad fan question in reply to marlowe, 09-11-2003 11:53:04
It seems to be a puller because air is blowing back across the engine ... just not a lot.
marlowe
09-11-2003 20:03:13
 Re: Re: Re: Re: Dumb rad fan question in reply to CityBoy, 09-11-2003 17:44:09
ok if the cup is to the front just unbolt and turn around should help unless it is bent
CityBoy
09-11-2003 20:36:02
 Re: Re: Re: Re: Re: Dumb rad fan question in reply to marlowe, 09-11-2003 20:03:13
Thanks. That's exactly what I'll do. Thought it looked backwards, and also thought it didn't move much air.
