What tractor should I buy? - open to ideas
dave
09-09-2003 06:47:39
Own 15 acres - need small tractor (20-40 HP) for wooded land (new house construction underway) land: snow plow, moving wood, etc. Want used. Don't necessarily want antique to to restore. My friends are suggesting an 8N, or a TO35 or Ford 661, or.... Many suggest a live PTO... HELP!!!!
charles blanton
09-13-2003 09:29:10
 Re: What tractor should I buy? - open to ideas in reply to dave, 09-09-2003 06:47:39
Boy are you stupid or just plain dumb? who makes decisions for you, your wife,mother,teenage son or who. Man or mouse? Come on,squeak up!
If you own a farm who is going to make the decision when to do what and why and how?
SHANNON
09-10-2003 01:20:04
since i brought a place 10 arces, mostly feild with hilly and grass grows like they are on drugs! mostly cutting the feild and grading the driveway and plowing snow..thats how i end up buying this massey harris 44, it was cheap and has more than enough power to do that simple work...nothing big and fancy.. get one with wide front if you have ditches and hilly... mine gets pretty wide like around 8 and half feet wide, it does job very good..might want to go with a bit bigger tractors than small ones like 8n, every once awhile you might need power and weight to do something heavy work, like pulling tree stumps and pulling trees around.. this mh 44 does it very well... its not too big but its not too small, just perfect and theres millions of mh 44's out there! good luck getting one..
shannon
CH
09-09-2003 14:44:31
Where do you live, what's the terrain like, how much do you want to spend? I'm thinking 4WD if your doing a lot of plowing.
MF-135 Deluxe
09-09-2003 13:30:45
Be all you'd need.
STEVEN H
09-09-2003 11:39:33
a classic 54 MH44s w/hitch all. gasser or diesel. hard to come by but best setup a guy could get. get it with duel disk brakes and live pto clutch and you are set, as the hydraulics for the 44 is allready live. live pto is in my opin over rated unless you have a loader on the tractor. i have heard that for baleing it is a must to have live pto,BS. i run an H farmall on my MHF #12 baler. and i never have had a problem that live pto would have mattered.
Chuck, WA
09-09-2003 08:20:16
Dave...bought my first about 18 months ago - MF35 Deluxe with Perkins 3-cyl diesel. Friend with an immaculate 8N suggested 8N or 9N, but when he took me to the guy he bought his from (retired fellow who reworks old tractors to sell), there was my MF on jack stands and I fell in love with it. When he finished the work on it and I got it home and my 8N friend had a chance to drive it, he drooled all over it.
I have only a little under 4 acres, and bought it to use to mow the fields, support consturction of a barn and addition to the house, and other chores. I hope to harvest a little grass hay for friends with horses using old, inexpensive equipment, but even there, not a lot of acreage. I was sure the MF35 was overkill. I couldn' have been more wrong.
Definitely want live PTO! 8N is around 27 hp, MF35 is 37 hp - not a trivial difference. Diesel is wonderful...wouldn't have it any other way. If nothing else, it SOUNDS like a tractor should sound! :)
On the other hand, my other friend has a very old, tired Farmall that he has no idea what model or age. Its 3-pt lift will stay up for a month, engine shut down, with a load - mine settles as soon as I cut the engine with no load. From what I hear, MF is notorius for that, but it just means I need to do a hydraulic pump overhaul. It's worth the exta effort for all the other advantages. By the way, when that friend borrows my MF35 to mow his horse pasture instead of using his Farmall, he drools all over it! :) Even just mowing with a bush hog, my 37 hp compared to his whatever makes it so much easier and faster.
Don't think you could go wrong with MF35. Others may comment on similarities between MF35, TO35, etc. I think it has to do with where it was built, but don't really know. Also, I guess there are some good advantages to getting a Deluxe model, but I can't say what all that means other than dual clutch, maybe extra gauges, floating cushioned seat, and I think some other things. Of course, I'm biased.
josh
09-14-2003 21:58:31
 Re: Re: Re: What tractor should I buy? - open to i in reply to paul, 09-10-2003 16:20:35
HAS AN 8N ONCE ,NEVER AGAIN ITS WAY TO WHIMPY COMPARED TO MY MASSEY 135 WITH MULTI POWER.THE DIESEL IS WAY STRONGER THAN THE 8N .ID HAVE TO SAY THAT THE 8N WOULD BE GOOD FOR HAULING AN EMPTY WAGON LOL .
