MF70 Loader/Backhoe Qn
Ryan
09-08-2003 19:53:42
I picked up one of these today for some work around the farm and such. One problem is that there is some slop/play in the backhoe when going from side to side. IE you stop it but it travels another 4-10 inches. What is need to fix this? Also does anyone know what the digging depth and reach on this thing is? I can measure the reach but I won't know the depth until I dig a hole.
Ryan
marlowe
09-09-2003 16:02:47
 Re: MF70 Loader/Backhoe Qn in reply to Ryan, 09-08-2003 19:53:42
std. hoe digging depth is 16ft. 4in.all hoes have a little after swing it is so there is not so much shock in the hyd.system if it stoped all at once you will spin the tractor around
Ryan in Ontario
09-09-2003 16:52:24
 Re: Re: MF70 Loader/Backhoe Qn in reply to marlowe, 09-09-2003 16:02:47
Thanks for the info. How does that compare to an average sized extra-hoe of today? Any other info I should know about the beast (except that it seems to be rare and hard to find parts for). Now all I have to do is find a cylinder for the bucket. The ones on there should be fine but the one does leak abit
marlowe
09-09-2003 19:08:20
 Re: Re: Re: MF70 Loader/Backhoe Qn in reply to Ryan in Ontario, 09-09-2003 16:52:24
had a 70 years ago but it burnt up i a shop fire it is about the size of a case 680 but more HP. i realy did like it but then i liked all the massey ind. stuff still use some every day . a good hyd. repair shop can fix the leek DON'T go to MF for the seals
