44 diesel
dodgeboy
09-08-2003 19:43:44
Hi
HI,
I just bought a 44 diesel standard. It was running OK, before the sale, then shut off. After the auction it wouldn't start except by pulling. once stared it runs good, but remains hard to start and sometimes will suddenly quit like it was shut off. While running I cracked the injecter line for each cylinder and the RPM dropped, so it was running on all four. I'm going through the fuel delivery system( cleaning steel lines and filter housing, replacing rubber lines)
My question now is. What is the canister right after the filter housing that is about 3"x6" and has a fuel line in and out and a 1/4" bolt, top and bottum for drain and bleeder?( how do I clean it? Back flush looks like the only option) Ray
Harold
09-08-2003 22:22:05
 Re: 44 diesel in reply to dodgeboy, 09-08-2003 19:43:44
Dodgeboy; You dont back flush it,you throw it away and replace it with a new one. It is a filter and it catches all the crud that the first filter lets through, I had one on a 44D that I owned and it sure saves the injector pump. I added one on my Oliver 88D and I never had pump trouble again. You can get them at Napa or Bumper to Bumper. Hope this helps, If your tractor wont start it is plugged and flushing it would get crap into your pump, and that costs bucks. Harold
dodgeboy
09-09-2003 19:15:04
 Re: Re: 44 diesel in reply to Harold, 09-08-2003 22:22:05
Thanks, Harold. I'm glad to get such a quick and clear reply. I will definitely get a new one. I took a JD diesel pump and its two injectors to a injection service for repair and it cost $475 and they had to replace only a copper washer in each injector. The rest was for cleaning and adjustment(and profit).
