MF85 Points closing
trigger
09-07-2003 14:50:40
Got a MF85 gasoline engine. Tractor will run anywhere from 1 - 6 hours and will shut off all of the sudden. Look at the points, and they have closed. I regap them, tighten them down, and run for a while before they will close again. Any idea what is going on? Nothing appears to be loose or broken in the distributor. Could it be electrical? I would appreciate any advise.
treewizard
09-17-2003 21:20:38
 Re: MF85 Points closing in reply to trigger, 09-07-2003 14:50:40
Check to see if the screw holding down the points has a lock washer in it. If it does, get a new one, if not put one on. I've had problems with this on my 85 and a new lock washer solved the problem.
dodgeboy
09-09-2003 19:24:55
Trigger, I bet the point rubbing block is wearing. Put a small dab of grease, the size of a match head on the point cam. That should stop the problem. Ray
