1959 ferguson to 35 steering
kent
09-07-2003 09:51:58
I just purchased a to 35 it has a leak under the steering wheel.bought new seal,oring.and bushing but cant get nut off steering wheel.also cant locate resivoir for power steering fluid. or does it pump from transmision ,also transmission fluid is low what type fluid should i put in. looks like it has hydraulic fluid in it now. this tractor runs great.i am really looking forward to putting her to work. your help will be greatly appreciated. thanks kent, centervill,tx
Kent
09-08-2003 18:53:14
 Re: 1959 ferguson to 35 steering in reply to kent, 09-07-2003 09:51:58
Thank you for helping me, John. Do you need to remove the battery box to get to the power steering resevior? Also, does the transmission and differential lubricate together? It seems to have hydraulic fluid in both, should I change both to mineral oil?
Kent McLean
ps. What town do you live in? My mother-in-law is from Twickenham, Middlesex. She has lived in Texas for many years though, but still is a British Subject.
john(UK)
09-07-2003 15:00:42
Straight Mineral oil 80/90 weight not detergent oil or hydraulic oil. If you cant find the resevoir for the power steering are you sure its got power steering fitted and it wouldn't take oil from the transmission to operate the steering even if it had it fitted later, the oil would be too heavy. What sometimes happens with the 35 here in UK is that water gets into the steering box and the oil floats on top of it and the level rises and so you have what you think is an oil leak. The filler for the steering box is under the battery on top of the box
