MF2135 stuck in reverse
Tyler(WA)
09-03-2003 21:31:25
I know this is a common problem and there's a trick to getting it unstuck. What is it?
Big Dean - has an article posted on his web site but I lost the URL.
Any help? email is appreciated.
Thanks
1
09-04-2003 05:57:53
 Re: MF2135 stuck in reverse in reply to Tyler(WA), 09-03-2003 21:31:25
The following is from Big Dean's web page.
Link
Getting the main shift lever unstuck Pull your filler plug for the transmission look inside you will see a big gear. Find a level spot shut off the tractor. Push the clutch down & put the high low shifter in neutral to relieve any pressure that might be on the gears. With a long screwdriver or a small pry bar pry the big gear forward if it is hung in reverse. Pry it back if it is hung in first gear. If you happen to go to far it will go in the other gear. You need to get it in the center. You should be able to feel the detent balls pop in the grooves in the shift rail as you move the gear. Through the years I have probably unstuck at least a 1000 of them this way. It is a common problem on the Massey tractors after they get a little wear on them.
Tyler(WA) Thanks!!!
09-04-2003 08:10:36
 Re: Re: MF2135 stuck in reverse in reply to 1, 09-04-2003 05:57:53
That's just what I needed.
