MF165 electrical question
Steve W
02-22-2000 18:58:40
Currently having problems starting my 165.
Not enough juice in battery to turn over the engine, lights work fine
I have to jump it with my car...
then it runs fine
i noticed that when running with lights on that the generator goes a little to the negative side of the dial
Do I need a new battery, alternator...what do i do from here?
Clarence Carhill
02-25-2000 06:04:51
 Re: MF165 electrical question in reply to Steve W, 02-22-2000 18:58:40
Steve... First charge your battery clear up and then put a load tester on it to check to see if you have a good one. Then use your load tester to see if the charging system is putting out 13.6 volts or more out over your system/battery. Next to a battery charger a load tester is the most important tool you can own to keep a tractor (or auto) starting and running. A Milton tester is the best brand to buy....
Gerald J.
02-22-2000 20:12:13
First try a new fan belt and maybe alternator pulley. A glazed fan belt cost me a car once, because it got hit while I was jumping another car with that problem.
Last year my JD 4020 wasn't charging well and the belt was worn out along with the generator pulley. Now it charges very well. Takes HORSEPOWER to spin the alternator when its charging and a bad belt can't accomplish that.
Then it that doesn't work try a regulator, then replace the alternator.
Gerald J.
