what size bush hog?
Old Cane
09-03-2003 20:30:00
I have a TO35 and the implements I have been getting are all 6'. They only stick out a couple of inches on either side and I've had no problems. I'm wondering if a 6' bush hog is too wide. I think a 5' would really be too small and I would be spending extra time mowing. On the other hand I don't want to hang a mower. What do you guys use?
garvas
09-09-2003 06:40:22
 Re: what size bush hog? in reply to Old Cane, 09-03-2003 20:30:00
I have a MF35 and mow with a 5 ft. brush hog. I think about a 6 ft, but sometimes in real tall grass I have to go into lower gears. I like to mow in 1st or 2nd high. I dought if you could do that in tall grass with a 6 ft. I am talking pasture land with grass 1 to 2 ft high.
BC
09-05-2003 19:53:29
I HAVE A 5 FOOT BRUSH HOG FOR MY MF35 GAS. IT CUTS GREAT BUT IT MAKES THE TRACTOR A LITTLE LIGHT IN THE FRONT. THE FRONT TIRES SEEM TO PUSH STRAIGHT WHEN I TRY TO TURN.
Bill
09-04-2003 08:50:05
I have been running a 5' on a MF50 diesel. The PTO is 38 hp. The gas, I believe for both 50 & 35 is about 32 hp.
My 50 runs the 5' bush hog with no problem and I like the cut. I had thought I'd get a 6' to extend out over the wheels but so far I am happy with the 5'.
Do you have a gas or diesel?
Bill
Old Cane
09-04-2003 10:21:05
 Re: Re: what size bush hog? in reply to Bill, 09-04-2003 08:50:05
Too bad I can't get a 5 1/2' bush hog.
I have a '59 model TO 35 that runs gas. I really like it so far. I think it outweighs my 600 series by a quite a bit which is great as I will be moving some round bales this winter. The only problem to date is getting stuck in gear. I did a search here on how to solve that. And this morning I had a bit of trouble keeping it running at first. We've had rain for days and it's been sitting outside. Took about 3 tries to keep it running at an idle then it was fine. By next week it's be parked under a roof so that should solve that problem. Then I'll change all fluids and filters.
