MF 65 mark I / II ??
Mat
09-02-2003 03:36:12
How can you tell the difference between an MF mark I and an MF mark II. Is there much difference?
Ali, fae Crieff.
09-03-2003 00:03:55
 Re: MF 65 mark I / II ?? in reply to Mat, 09-02-2003 03:36:12
Hi Mat, I can't comment on U.S.tractors but those built at Coventry would appear as follows:-Mk1
A4.192 indirect injection diesel engine, small fuel tank and two 6volt batteries, larger inlet manifold,injector feed pipes horizontal,and it also has a separate wedge shaped segment to the rear of the cast sump.Mk2:- AD4.203 direct injection diesel engine,larger fuel tank with one 12volt battery,narrower inlet manifold,vertical injactor feeds,and no wedge to sump.Early Mk1's also had a sloping oil filter housing although mine is vertical being a late Mk1.
Hope this helps you,
Cheers Ali.
