HELP!I recently purchased a MF 135 with a Continental Z145 gas engine. It ran fairly well for a while. The oil pressaure reads 18 to 19 and increases 20 at higher RPM�s. Is that okay? The transmission oil is milky yellow. Should it be changed? What oil should I use? The starter solenoid engages the starter for only a short time before it starts spinning. The battery is strong and the connections are good. Do you have any suggestions for lengthening the time that the solenoid engages the starter? The PTO arms seem to lift okay and hold the same position but this occurs only when a sliding lever on the right side of the seat is in the full upright position. Is that the way it is supposed to work? I�m not sure what the draft lever is supposed to do. Now, the electrical system is completely dead. Nothing happens when the ignition switched is turned on. The solenoid, starter, lights, and gauges don�t work. The ignition key will start the engine and the gauges will work (except maybe the amp meter) only when I connect a jumper wire from the positive terminal of the battery to the battery terminal on the ignition switch (the switch cannot turn off the engine). Thanks. John (a true novice)
