seal on imput shaft leaks on 44
STEVEN H
08-26-2003 11:24:43
since i have the motor and clutch out i am going to replace that leaking seal in the front trannsmition case. i have the gear off the shaft, but want to know what to expect when i take off the cover. also does the new seal just slide in? or will i have to rip the transmition apart to replace it? i have also desided that i may as well replace the clutch too, the old one is not bad and works good still. but ifeel that i may as well replace since i have the tractor this far apart.what should i replace? just the clutch pad? should i get a clutch kit and replace the whole thing?even if i was not to replace any of the clutch i will replace the bearings. what other items might i want to consider to replace right now since i have the tractor this far apart?
any words of advice or tricks to make things go as smooth as glass?
bob
08-27-2003 10:36:27
 Re: seal on imput shaft leaks on 44 in reply to STEVEN H , 08-26-2003 11:24:43
don,t worry about clutch as all you have to do later is disconnect u joint and raise motor pull hogshead and clutch not a very hard job with chain hoist also on that croove on trans shaft they do make jiffy collars which is a very thin like bushing but think jb will work as no speed good luck
JDBert
08-26-2003 12:54:42
Steven, I dont know which type of connector you have but My 49' had the chain style and later they replaced that with a rubber type connector. Either way after you get that off the input shaft theres a cover with three bolts that comes off and has the seal in it. My shaft had a grove wore in it, so I took some JB Weld filled and sanded to back smooth and that seems to be working good. For the clutch I just sent my disk away and had it resurfaced, because the pressure plate was good and I just re greased the throwout bearing. Now for the bad news, the bearings are hard to get, I had to have my local napa store order them and if I remember right the large rear one was over $60. The best thing to make sure you do on reassembly is to clean clean clean all surfaces and you shouldn't have any trouble.
STEVEN H
08-26-2003 13:37:14
 Re: Re: seal on imput shaft leaks on 44 in reply to JDBert, 08-26-2003 12:54:42
ouch, them bearing realy are big $$$. i think that i am going to soak mine in kero and than oil for a while befor i put them back in. i hope that my imput shaft is not wore but that jb weld is a good idea. but i still want to know, can i replace that leaky seal with out riping into the whole transmition? thanks SLH
JDBert
08-27-2003 07:17:46
 Re: Re: Re: seal on imput shaft leaks on 44 in reply to STEVEN H, 08-26-2003 13:37:14
The seal comes off with the plate this is all you have to take off. There will be a bearing directly behind it though, so after you take the seal plate off make sure not to put it in gear. My dad did this while I was working and it pushed the bearing out, not much fun to get it lined back up.
