Loader for 1958 Model 65
Montie Guthrie
08-25-2003 20:03:03
Need info as to where to go about finding a loader to fit on a model 65. will only certain types/models fit?
Tim
09-03-2003 19:38:18
 Re: Loader for 1958 Model 65 in reply to Montie Guthrie, 08-25-2003 20:03:03
Many types of loaders will work on your tractor.
Since it doesn't have p.s. it will be somewhat harder to steer with a loader and the load in your bucket. I have seen Allied, Robin, Davis
loaders mounted on this model tractor. They mount
at the front at the four large tapped holes and at the rear using the long fender bolts; which
may have to be lengthened or new ones used.
The 65' has a very strong front axle. I owned one
with a Davis industrial loader and front pump!
James In MO
08-26-2003 18:51:25
Now I may be wrong but I was told at the Ford dealer that as long as you had the four tapped holes on each side behind the fron axle and power steering you could get a Koyker or Westendorf loader
Montie
08-27-2003 18:00:38
 Re: Re: Loader for 1958 Model 65 in reply to James In MO, 08-26-2003 18:51:25
Power steering??? All I have is armstrong. Does that mean I'm sunk? Should I go see my Ford dealer?
James in MO
08-28-2003 05:41:26
 Re: Re: Re: Loader for 1958 Model 65 in reply to Montie, 08-27-2003 18:00:38
You will need the power steering when you add all that weight on the front if I remember right they used the pump to run the loader but I have seen the Westendorf's hook into the auxillary on the back the Ford dealer is also the Koyker dealer fiond someon that deals in either Koyker or Westendorf around here Koykers are a little less expensive
