Massey industrial..Popping noise
Rick
08-25-2003 13:19:32
Purchased a MF40 Industrial with a 3cyl perkins gas it has a popping sound intake and exhaust 3rd cyl..head was redone 50 hrs ago any suggestions..Thanks Rick...serial # 9A I i think 69919
TO-35Man
08-25-2003 16:33:31
 Re: Massey industrial..Popping noise in reply to Rick, 08-25-2003 13:19:32
Sounds like a worn cam lobe or broken valve spring I'd run a compression test first or I'd remove valve cover and turn the engine over and look for a broken spring or valve not moving up and down ....
another quick way to find it is to run the motor and pull 1 plug wire at a time till the noise disappears...that will be the cylinder it is..
hope this helps....
