where could i purchase synthenic oil for mh 44?
SHANNON
08-25-2003 00:06:07
anyone know a store that sells synthenic oil for tractor mh 44 260? to squeeze abit extra horsepower for pulling... thanks shannon
Earl
09-06-2003 05:19:00
 Re: where could i purchase synthenic oil for mh 44 in reply to SHANNON , 08-25-2003 00:06:07
Get the oil anywhere, but make sure that you have new seals and gaskets for you tractor.
You will not believe how many oil leaks you never knew you had.
True hp increases can only be obtained by mechanical means.
Doug in OR
08-30-2003 14:44:32
You can get synthetic just about anywhere. Mobil-1. AMSOIL. Even Quaker State sells a synthetic. The main reason you "might" get a slight increase in HP is because synthetic flows easier. You'd get nearly the same advantage if you switched from say... a 20W-50 oil to a 10W-30 oil. No need to stick with a straight weight 30 oil just because it was the best available back when the tractor was made. Modern multi-weight oils are far better than the old single weight oils from 50 years ago.
In a stock motor like this, I doubt that switching to synthetic will give you much. I'd venture to say not even a single HP of improvement.
Oldfarmboy Jim
08-25-2003 21:10:54
You might also squeeze more than a bit of synthetic oil out of the tractor too. If your tractor has always used normal petroleum based oil, switching now may give you many small leaks at various gaskets and seals. Something about the molecular structure of the synthetic. Best time to introduce synthetic oil is right after a rebuild.
STEVEN H
08-25-2003 16:31:49
try a dealer. they might have it other wise your local farm store should
