MF 135 Problems
John from Buffa
08-24-2003 16:44:18
HELP!
I recently purchased a MF 135 with a Continental Z145 gas engine. It ran fairly well for a while.
The oil pressaure reads 18 to 19 and increases 20 at higher RPM�s. Is that okay?
The transmission oil is milky yellow. Should it be changed? What oil should I use?
The starter solenoid engages the starter for only a short time before it starts spinning. The battery is strong and the connections are good. Do you have any suggestions for lengthening the time that the solenoid engages the starter?
The PTO arms seem to lift okay and hold the same position but this occurs only when a sliding lever on the right side of the seat is in the full upright position. Is that the way it is supposed to work?
I�m not sure what the draft lever is supposed to do.
Now, the electrical system is completely dead. Nothing happens when the ignition switched is turned on. The solenoid, starter, lights, and gauges don�t work. The ignition key will start the engine and the gauges will work (except maybe the amp meter) only when I connect a jumper wire from the positive terminal of the battery to the battery terminal on the ignition switch (the switch cannot turn off the engine).
Thanks.
John (a true novice)
Will
08-25-2003 05:30:32
 Re: MF 135 Problems in reply to John from Buffalo, 08-24-2003 16:44:18
In addition to following David's advice I would find your local MF dealer and purchase the operators manual, parts manual and service manual.
Find a local who can spend an hour with you explaining and demonstrating the basics, maybe there is a local antique tractor club, a farmer neighbor, etc. Purchase the CD offered by Big Dean
([email protected]), I have 2 MF135's, one diesel and one gas, and Big Dean's info has been extremely helpful.
kirkC,
04-28-2005 21:46:16
 Re: Re: MF 135 Problems in reply to Will, 08-25-2003 05:30:32
To Big DEAN,
I just got your E/ mail Dean,
It,s about 11;33 here in Alton Kansas,
I loved reading your letter that you just did,
I was Impressed at you telling me about the seal,as in the 2000 serie,s Massey,s,
they are really nice if you find a good one,
But on the other hand an 1155 would be a better bet as It is more relible overall I think,
and probably simpler to work on,
Yes your right about the hydralic,s on the 1100 serie,s,
there is no better system than Massey,s,
they were way ahead of their time on alot of thing,s,
Thank,s sooo much again Dean for all the help
that you give all of us Massey Nut,s out there,
It,s sooo much appreciated,I can"t tell you,
Ill Talk to ya later ok Dean?
And thank,s again,
Kirk Conway,
David
08-25-2003 02:28:27
Ol pressure sounds ok.
Transmission oil has water in it and has emulsified, hence yellow colour. Defintely change it. I won't suggest what to use as UK specs are different to US but there is info on this on the site.
I'd make sure all connections bewteen starter and battery are good and if that didn't work, strip solenoid and give it a clean makign sure everything moves freely. No guarantees on that advice though as I have the same "feature" with a car just now and haven't tackled it yet. That's what I'll be trying though.
Hydraulic controls have a lever for position control and one for draft control. Draft control is a form of mechanical load sensing and when using something like a plough (or plow) it monitors the load and raises and lowers the implement slightly to maintain a constant load. (and so avoid the problem of the tractor coming to a halt when it hits a tough patch of ground) Normally for non ground engaging implements you use the position control lever to control height with the draft control lever three quarters to up position. There is also a "Constant Pumping" sector on control quadrant and you need to keep levers out of that unless you are using an external hydraulic motor of similar. If you have it constant pumping without an outlet you'll hear a knocking from back end which I think is the pressure relief valve operating. It is damaging if you let it continue for a long time. Operators manual explains all.
Wiring. There is normally a feed to the ignition switch from the permanently live terminal on the solenoid. It's usually quite a thick wire but nowhere as thick as the starter cables. Sounds like either it is not attached (at solenoid or switch end)or cable has a break in it somewhere. Your jumper sounds like its doing the same job. If wire is attached, I'd do a continuity test on it although I hav erearely found broken wires in a harness. Usually its joints and terminals that are the problem.
