MF 1100 Series and 2700 Series
Trever Maas
08-22-2003 20:50:36
Could anyone tell me anymore about these series of tractors in the '60s, '70s, and '80s? I know the 2700 series had it's share of problems, we know from experience. What about the 1100 series? Any particular one pull better? I know the 1155 and the 2745 share engines right? Any internet sites, links, or literature that I could read? I would love to talk MF. Been a fan my whole lifetime and possibly plan on being an MF mechanic.
Thanks!
Trever Maas
MF 2745
GT
08-27-2003 08:08:26
 Re: MF 1100 Series and 2700 Series in reply to Trever Maas, 08-22-2003 20:50:36
Hi All:
Just purchased a MF 1100 from a reputable dealer here in Central Iowa. The tractor is gas, great shape, with only minor problems.
Here's my question: The brakes are unbelievably sensitive, and lock up when barely touching the pedal. I'm not Massey guy, but asked the dealer if he could have them fixed. He said that they are hydraulic brakes and that's how they work. Any suggestions on how to lighten the pressure on these brakes, or is the dealer taking me on a hay ride?
Thank you. GT
Roy in UK
08-27-2003 09:18:55
 Re: Re: MF 1100 Series and 2700 Series in reply to GT, 08-27-2003 08:08:26
Neither a hay straw or a silage ride GT, the brakes on an 1100 are very very keen! They were a bit to keen at times. Having said that I do not know whether the US version had a ( mechanical )handbrake, ours had one and it was rubbish. If the tractor was left unattended it was a lot safer to use the 'P' (parking lock) position on the gear change.
GT
08-27-2003 11:25:13
 Re: Re: Re: MF 1100 Series and 2700 Series in reply to Roy in UK, 08-27-2003 09:18:55
Thank you Roy. No hand brake on this model. I was instructed to always leave in "Park" when unattended. Scarey part is...hydraulic brakes don't work when tractor isn't running. "Park" gear in my vocabulary is reserved for Buicks and Oldsmobiles. Thanks again.
Trever Maas
08-24-2003 08:33:21
Thanks Roy! I've seen a lot of pictures of Massey's overseas. Must be pretty popular. Also some pulling pictures. My grandpa just sent some tractors with a guy that was going to ship them over to Belgium, the guy must be a scalper. Several Farmall Regulars, Minneapolis Molines, I think this guy was up in Canada and got some steam and stationary engines, and some more tractors in the U.S. Supposedly selling them in Germany. What do MM's and MF's generally sell for over there?
I've got another question for you guys. On the 1100 series(1105,1135,1155), if I can remember right, there was a lever to the left of the steering wheel that did something to the engine i.e. slowed it down or speeded it up. Does anyone have a picture of this or know what is is, does, and the priciple of it? I think I can remember going in the field and if the tractor lugged too much you could move the lever to give it more power or if you were coming to the end rows you could move the lever the other way to help slow it down. Would it be a multipower, type thing?
Thanks,
Trever
Roy in UK
08-24-2003 15:10:43
 Re: Re: MF 1100 Series and 2700 Series in reply to Trever Maas, 08-24-2003 08:33:21
Thats right, multipower "Shift to high for engine braking". A very useful thing to have, although you cannot tow-start a multipower tractor. having said that, our 1100 was a wonderful starter.
Trever Maas
08-24-2003 16:47:21
 Re: Re: Re: MF 1100 Series and 2700 Series in reply to Roy in UK, 08-24-2003 15:10:43
Thanks Roy!
Can you tell me the operation of it, or the principle? I'm very interested in these tractors!
Thanks,
Trever
Roy in UK
08-24-2003 23:43:25
 Re: Re: Re: Re: MF 1100 Series and 2700 Series in reply to Trever Maas, 08-24-2003 16:47:21
Well Trever I am no mechanic,but I can tell a bit about how it works . The idea of Multipower was to effectively double up the gear ratios of the standard 6F 2R gearbox. Multipower provided you with 12F 4R gears. when the tractor was in gear, you could flick the MP switch into high to give you another 'half' gear. It was useful for say baling, if you were baling hay ( or straw) and you encountered a 'lighter' spot in the windrow, you could flick into high without de-clutching. If you were say ploughing in a high multipower gear, say 3L high multipower, and you hit a bit of heavy clay, you could flick into low to get you through a tough spot. I can remember pulling a 21' 6" spring tine cultivator with our 1100. Normally you could run it in 1st high, high multi. As I approached the headland I would flick into low, cut the rpm, pick up the spring tine, turn the tractor around, lower the spring tine back on the ground, rev up, then flick back into high. It made a nice sound too as the multipower engaged....what a growl from the engine! It was a nice tractor, but to be honest I think it was designed for travelling across the dry plains of Kansas! It was a bit 'top heavy' if you catch my drift. If you had had a lot of rain it was best to leave it in the shed! Dad used to say it was 100hp but need 20 of them to move itself around. Nowadays a farmer in Europe would not look at a tractor that size unless it had 4 wheel drive.
Trever Maas
08-25-2003 14:30:01
 Re: Re: Re: Re: Re: MF 1100 Series and 2700 Series in reply to Roy in UK, 08-24-2003 23:43:25
Thanks Roy.
Do you know which models all had that multipower switch?
Trever Maas
08-27-2003 16:48:06
 Re: Re: Re: Re: Re: Re: MF 1100 Series and 2700 Se in reply to Trever Maas, 08-25-2003 14:30:01
Sorry for not replying sooner.
Thanks for the links Roy and Johan! Very good pics and info Johan. I found the books that you were talking about Roy. They have both of them. The 2nd version is not available though, maybe on backorder.
Thanks again,
Trever
Roy in UK
08-25-2003 23:41:29
I am with Johan on that one!
I can also recommend 2 books,( which I have, they are excellent) The Massey Legacy volumes 1 and 2 by John Farnworth. These are British Books, by an English author, but I had a look and I see they feature in the U.S. Amazon website. Just enter "Farnworth" in the search box under books.
Johan S
08-25-2003 22:01:38
Hello! It's almost easier to tell wich model couldn't be fitted with Multipower. If you want to read more about the Massey's, please check out these sites Link
Link href="http://www.fofh.co.uk/index.htm">Link
The first one is from Norway. It's still under construction, but has already a lot of history and nice pictures. The second one has links to a lot of good Massey sites.
By the way, I have a '57 Massey Harris Ferguson FE-35 diesel and a '74 M F 1080-8, both are running just fine.
Regards
Johan
Trever Maas
08-24-2003 11:27:07
I think what I was talking about was the 11X0 series, meaning 1100, 1130, and 1150. Maybe there was some sort of toggle switch or something.
Merle
08-23-2003 04:28:05
Trever
The 11XX series was one of the best series Massey put on the market. Our first BIG tractor was a 1130, next we moved up to an 1155. Then after I quit farming my brother picked up a 2805 cheap (what a horce). I have since moved back to the farm and an looking for a 1105 or 35 because the cabs are easy to get in and out of and never really cared for the V-8.
Merle
Trever Maas
08-23-2003 08:51:45
 Re: Re: MF 1100 Series and 2700 Series in reply to Merle, 08-23-2003 04:28:05
Hi Merle,
Thanks for replying. Which tractors have the six cylinder engines in them? What size are 6 cylinder engines? Same as the ones in the 750 combine? Do all the six's have turbos?
I was also wondering which tractors are able to have the cabs tooken off if wanted? I think they look pretty tough with the cabs tooken off. Also, which models can be turbo-ed or already have a turbo?
I wouldn't mind an 1150 or an 1155. I would like something that is over 150HP, or capable of getting there. Might end up pulling it too. I think we've had an 1135, an 1150 or two, an 1155, a 2775, and now we have a 2745, plus we've had at least one 510 and now we have a 750. Massey Ferguson red is definately in the blood. :) We also are a fan of MM's.
Back to the MF's. Like I said we currently have a 2745. Why did they have so many problems with the 27XX series? The tractor has just been a nightmare. Multipower problems 2-3 times so had to have the tractor split, power steering problems at low rpms, AC problems, instrument cluster problems, and we sometimes get a buzzer when the pto is engaged or the multipower is shifted. It is a workhorse when it is in use though.
How come you don't like the V8's?
Thanks,
Trever
red-n-green
08-23-2003 16:25:39
 Re: Re: Re: MF 1100 Series and 2700 Series in reply to Trever Maas, 08-23-2003 08:51:45
The 2705 is a turbo with a 354.4 cubic inch perkins inline 6cyl. The 2675 is the non turbo with the same engine.
The 1105 and 1135 have an earlier version of the 354 perkins. Both of these are turbo models I think.
Jay
Roy in UK
08-23-2003 23:39:43
 Re: Re: Re: Re: MF 1100 Series and 2700 Series in reply to red-n-green, 08-23-2003 16:25:39
The 1100 was non turbo.
We ran one from new between 1969 and 1996. when we sold up it made a lot more in the sale than we origionally paid for it ( a rare bird over here! )
marlowe
08-23-2003 13:58:27
i worked for a massey dealer and the reason the 2000 series had a lot of problems was that that JD came out with there power shift and massey was 2 years out from putting the tractor on the market but money talks and massey put it out and it was NOT up to par they just did't have testing done and it did't hold up. and also at that time massey was having labor union problems and we seen a lot of sabatage [rubber bands in fuel tank.parts missing on and on]
Roy in UK
08-24-2003 05:23:07
 Re: Re: Re: Re: MF 1100 Series and 2700 Series in reply to marlowe , 08-23-2003 13:58:27
The 2000 series MF were not too highly thought of over here. Smokey and underpowered. A neighbour of mine had a 130h.p. MF 2000 series and also a 110 h.p. Renault ( both 4 wheel drive ). He used to pull a 4 furrow 14" reversible with his Massey and a 5 furrow 14" reversible with the Renault.
Trever Maas
08-23-2003 14:08:03
Marlowe,
Thanks for your reply!
It seemed like Massey was/is underrated. All I hear is John Deere this and John Deere that. Who was doing the sabatage?
I'm thinking about working for a MF dealer after I get through college. Would you recommend it? I really like their products, at least their older stuff. I just wish that they didn't make a bad name for themselves.
Trever
