MF2200 INDUSTRIAL TRAC TOR PTO RETROFIT
RNASH
08-22-2003 13:47:29
My MF2200 industrial tractor with instareverse transmission does not have a PTO. The parts manual shows the parts I could buy to retrofit it. The problem is that I don't know if you can add the PTO with an instareverse hydraulic transmission. And if it is possible, can I do this without breaking the tractor apart?
Gary F
08-22-2003 14:59:08
 Re: MF2200 INDUSTRIAL TRAC TOR PTO RETROFIT in reply to RNASH, 08-22-2003 13:47:29
You should be able to do the retrofit. Are you going to have 3 point hitch? If you are not then you will only need shaft and bearings. If you want 3 point you will need another lift cover, the hydraulic pump and a PTO shaft and bearings/bushing. The MF 135 might be the source of parts. The PTO spins backwards when you reverse the Tractor with the PTO engaged not good for snowblowing! I have had this done on my MF 204 it cost me about $1000 can and It was done by a repair shop not a dealer.
Big Dean has some info about this on his website
Good luck
Gary
Rnash
08-25-2003 08:34:37
 Re: Re: MF2200 INDUSTRIAL TRAC TOR PTO RETROFIT in reply to Gary F, 08-22-2003 14:59:08
Thanks gary, I am going to do it. I already have 3-pt lift on this tractor.
