Lifting capacity of MF135.
Jack M, UK
08-21-2003 12:37:22
I have an MF135 with a 3cyl perkins diesel engine and I was wandering what the lifting capacity of the 3pt linkage was (just curious).
Thanks for the feedback, Jack M, UK
Lasse
08-21-2003 16:01:44
 Re: Lifting capacity of MF135. in reply to Jack M, UK, 08-21-2003 12:37:22
1300 Kilo at the end the arms. It's the same capacity for all MF35 children up to the MF240
Will
08-21-2003 13:12:45
I have the same tractor, I seem to recall reading in one of the manuals that the limit was either 700 or 750 pounds.
David
08-23-2003 21:38:31
 Re: Re: Lifting capacity of MF135. in reply to Will, 08-21-2003 13:12:45
Defintely isn't 700 pounds. You could hardly lift anything with only that at links ends. 1300kg sounds about right to me but you do have to remember that is quoted at link ends. All implements hang out the back so weight of implement that you can lift is always less than link end lift. Sometimes a lot less, if it has a big overhang and weight at the back. Practical lifting limit is what it can handle and still keep the front wheels on the ground some of the time, with weights and wheel ballast on the front if necessary.
