TO35 oil leakage out of starter housing
Doug
08-21-2003 10:35:00
Can someone tell me why I have oil leaking out my starter housing and can I keep running it like this or what do I have to change? thanks and anyone know a wiring diagraham on a to 35 1957?
marlowe
08-21-2003 16:45:13
 Re: TO35 oil leakage out of starter housing in reply to Doug, 08-21-2003 10:35:00
your little drain hole at the bottom of the bell housing is pluged with dirt there should be a cotter key in the hole to keep it open. if the cotter key is gone thats why the hole is pluged.your clutch is more then likely coverd with oil also. is it trans. or engine oil?
Doug
08-22-2003 08:42:19
 Re: Re: TO35 oil leakage out of starter housing in reply to marlowe, 08-21-2003 16:45:13
I think it is engine oil, so if I unplug the hole I can keep going like that or I have to change a seal?
marlowe
08-22-2003 09:30:09
 Re: Re: Re: TO35 oil leakage out of starter housin in reply to Doug, 08-22-2003 08:42:19
you can run it like that but like any thing it will not fix it self.
