MF 35 MULTIPOWER
Gary S
08-19-2003 14:15:19
Would like to know how to Adjust multipower it licks down on side hill fuild level full someone said it needed ajusting Thanks Gary
Big Dean
08-20-2003 09:36:20
 Re: MF 35 MULTIPOWER in reply to Gary S, 08-19-2003 14:15:19
The only adjustment on the Multipower is the one for the shift linkage If it shifts into both ranges when you move the lever it is OK. what causes the problem of it kick back in to low range under a hard pull is because of low pressure to the clutch pack. It could be seals leaking or a weak Multipower pump. Email me if I can be of further help
