1100 Multi power problem
tooly
08-18-2003 22:35:55
A relative of mine has a 1100 Massey which seems to have lost its drive through the multi power. It is presently disasembled,and they dont see anything obvious wrong. clutch plates seem ok, as is the sprag clutch.Any info as to possible causes ,and an explanation of how multi power works would be appreciated. Does it have its own pump to pressurize the clutch or does main hydraulic pump supply the pressure? I presume there is a piston which appies the clutch?
Thanks guys
Rob
08-20-2003 16:14:25
 Re: 1100 Multi power problem in reply to tooly, 08-18-2003 22:35:55
Does the pto work? It might be the charge pump under the floor panels. Did you check the linkage on the valve? We had the pump lock up and shear a key for the gears in the pump. There is two sides to the charge pump. One is to feed the front pump and the other is to feed the multi power and pto valve.
Rob
