F40 serial number prefix?
DG
08-18-2003 11:14:40
Our big tractor has the prefix CGM which we figured out stood for Continental Gas Motor.
The little one has the prefix SGM.
Can you tell us what this one means?
It is a 4 cylinder gas motor with these numbers in the Port side of the block: A 29 T
and lower down Z1 34A-602.
D&G
Paul in AZ
08-19-2003 17:36:13
 Re: F40 serial number prefix? in reply to DG, 08-18-2003 11:14:40
Here are the Ferguson/MF prefixes used during that era:
S Standard/Utility C High Clearance/Hi-arch
R Row-crop two wheel
T Row-crop single wheel
J Industrial/multi-purpose
V Vineyard
G Gasoline
H High altitude gasoline
B L. P. G.
D Standard Diesel
N Perkins Diesel
K Vaporizing Oil (TVO)
L Lamp oil
F Single-stage clutch
M Dual-stage clutch
Y Differential lock
W Multi-power
Don Bader
11-09-2003 14:21:08
 Re: Re: F40 serial number prefix? in reply to Paul in AZ, 08-19-2003 17:36:13
Do you know anywhere to get info. on a Ferguson F40 High Clearance? I have on with serial # CGM400488 and am looking for any info. on this. I plan to restore it and am looking for any info. It is very hard to locate.
Please respond if possible.
Regards,
Don Bader
DG
08-19-2003 18:32:26
Paul, That makes sense thank you so much.
G&D
Bill
08-18-2003 11:36:20
I'm working from memory here so someone correct me if I am wrong!
SGM
S = Standard (vs say hi-clearance)
G = Gas
M = Manual
The rest I don't know.
Bill
