101jr charging
Jim
08-17-2003 07:48:13
I just had the generator rebuilt by a rebuilding company, so I assume it has been done right. But, it gets hot when the tractor is running. I have an 8 volt battery and rewired the tractor as the old wireing harness was(took out one wire and replaced it then another ect.) and put in the orginal style light switch (3 position--off-on to charge-lights). Have I missed something? Resistor wire? I'm stumped. Maybe someone could post a diagram or guide me thru? Thanks.
Alberta Mike
08-17-2003 14:12:28
 Re: 101jr charging in reply to Jim, 08-17-2003 07:48:13
Where are the two wires that leave the generator connected to after they leave the generator? One should be from the relay cutout box and the other should be from the field terminal coming out the side of the generator case.
